http://www.chinakangying.com/ky2/docc/p ... =2&P_ID=38
Product Name: XY400GY(EEC,400CC)
Product size(mm)2210x860x1200
Wheelbase (mm):720
Mix ground clearance (mm): 300
Dry weight(kg):132
Gross weight (kg):182
Fuel tank capacity(L):9.0
Seat height(mm):880
Battery type:12v/7AH
Brake mode(front/rear):disc brake/disc brake
Brake operation mode(front/rear ):hand/foot
Engine type:single cylinder 4-stroke
Engine number:XY191MQ-2
Bore*stroke(mm):91*59.5
Displacement(ml):387
Compression ration:10.0:1
Max power/ running radius:22/7500kW/(r/min)
Rated power /running radius : 20/7500kW/(r/min)
Max torque /running radius:32/5500 N.m/(r/min)
Mim fuel consumption (g/kw/km ):367
Ignition :C.D.I.
