Есть (электронный) спидометр и тахометр KOSO (комплект)
Спидометр
KOSO DIGITAL SPEEDOMETER DL02-S
KOSO® digital speedometer
Digital LCD speedometer in black housing with easy-to-read blue LCD display. Housing dimensions diam. 55 mm, depth approx. 48 mm, diam. of display approx. 49 mm. Suitable for two- and four-stroke motorcycles and also quads and ATVs with 12 V DC electrical system and battery. Incl. fittings, device bracket incl. clip for 22 mm handlebar, and installation and operating instructions in German. Installation requires expert knowledge of vehicle electrics.
Up to 260 km/h
Digital speed indication up to 260 km/h
odometer up to 99,999 km
Trip counter up to 999.9 km
Fuel level indicator with warning function
Fuel level indication via fuel level sensor 100 or 510 ohms, if the vehicle is equipped
Wheel sizes programmable in 1 mm steps from 300 - 2,500 mm
Incl. pulse transmitter with sturdy bracket
А так же тахометр
DIGITAL TACHOMETER KOSO,DL02-R
KOSO® digital tachometer
Digital LCD tachometer in metal housing with easy-to-read blue LCD display. Housing dimensions diam. 55 mm, depth approx. 48 mm, diam. of display approx. 49 mm. Suitable for two- and four-stroke motorcycles and also quads and ATVs with 12 V DC electrical system and battery. Suitable for both transistor-controlled and CDI ignition systems. Incl. fittings, device bracket incl. clip for 22 mm handlebar, and installation and operating instructions in German. Installation requires expert knowledge of vehicle electrics.
Up to 20,000 rpm
Digital engine speed indication up to 20,000 rpm
adjustable scale between 10,000, 15,000 and 20,000 rpm
2 temperature displays (please also order the appropriate adapter)
Digital clock
Incl. temperature sensors
Это типа комплект
Цена за комплект - 175 евро.
Цена при продаже отдельно (или спидометр или тахометр) - 125 евро
Спидометр
Up to 260 km/h
А так же тахометр
Up to 20,000 rpm
Digital clock
Это типа комплект
- ShaitanArba
- Мотоцикл: KTM 390 Duke '13
Закинул элиминаторщикам, там новенький на длиннохвостом родную приборку сменить хочет.
Не знаю, зачем ему это, но может и взять.
Я правильно понимаю, что приборка:
а) есть в наличии?
б) в чёрном глянцевом корпусе?
а) есть в наличии?
- brother_ilia
- Site Admin
- brother_ilia
- Site Admin
- Юраё
- Мотоцикл: Yamaxa XV 1600 Road Star
Мне интересно куда девать контрольные лампочки после установки электронного спида. Вот в чем вся проблема.
А вообще где то видел, у чела был установлен спидометр от какогото легкого самолёта, который работал от потока встречного воздуха.
Такой бы найти)) Только точность думаю будет очень сомнительной))
962 680 25 06
Как можно заметить, данная темаNOlim писал(а):не. просто у меня каст спидометр, а под баком кучка проводов вот.
надо паходу планшетку такую с диодами и схему какой провод за че закреплен.
про продажу вышеозначенного оборудованияendeneu писал(а):Есть (электронный) спидометр и тахометр KOSO (комплект)
Про электрику есть тут
Электрооборудование
Про спидометры (и замену) есть тут
Спидометр ( установка , перенос , замена на цифровой )
Что куда выводить - "хозяин-барин"
Схема "разводки" есть тут
http://hondasteed.org.ru/files/wiring.jpg
На спидометре или на доп девайсеNOlim писал(а): на счет контрольных ламп. 3 шт. на траверсе зажигание, поворот, свет дальний. а где давление, где это должно быть???
NOlim писал(а):не траверсе все работает. лампочка температуры очень нада, а она на спидометре, у меня каст там нет. кароче хочу скалхозить тока по феньшую. может знаеш какие там (еще лампочки) на родном спидометре?
endeneu писал(а): Как можно заметить, данная темапро продажу вышеозначенного оборудованияendeneu писал(а):Есть (электронный) спидометр и тахометр KOSO (комплект)
Электрооборудование
