Есть (электронный) спидометр и тахометр KOSO (комплект)
Сообщение endeneu » 20 июн 2011, 19:54
Спидометр
KOSO DIGITAL SPEEDOMETER DL02-S
KOSO® digital speedometer
Digital LCD speedometer in black housing with easy-to-read blue LCD display. Housing dimensions diam. 55 mm, depth approx. 48 mm, diam. of display approx. 49 mm. Suitable for two- and four-stroke motorcycles and also quads and ATVs with 12 V DC electrical system and battery. Incl. fittings, device bracket incl. clip for 22 mm handlebar, and installation and operating instructions in German. Installation requires expert knowledge of vehicle electrics.
Up to 260 km/h
Digital speed indication up to 260 km/h
odometer up to 99,999 km
Trip counter up to 999.9 km
Fuel level indicator with warning function
Fuel level indication via fuel level sensor 100 or 510 ohms, if the vehicle is equipped
Wheel sizes programmable in 1 mm steps from 300 - 2,500 mm
Incl. pulse transmitter with sturdy bracket
А так же тахометр
DIGITAL TACHOMETER KOSO,DL02-R
KOSO® digital tachometer
Digital LCD tachometer in metal housing with easy-to-read blue LCD display. Housing dimensions diam. 55 mm, depth approx. 48 mm, diam. of display approx. 49 mm. Suitable for two- and four-stroke motorcycles and also quads and ATVs with 12 V DC electrical system and battery. Suitable for both transistor-controlled and CDI ignition systems. Incl. fittings, device bracket incl. clip for 22 mm handlebar, and installation and operating instructions in German. Installation requires expert knowledge of vehicle electrics.
Up to 20,000 rpm
Digital engine speed indication up to 20,000 rpm
adjustable scale between 10,000, 15,000 and 20,000 rpm
2 temperature displays (please also order the appropriate adapter)
Digital clock
Incl. temperature sensors
Это типа комплект
Цена за комплект - 175 евро.
Цена при продаже отдельно (или спидометр или тахометр) - 125 евро
Сообщение endeneu » 20 июн 2011, 20:00
PS цвет - черный
inflamer
Сообщение inflamer » 20 июн 2011, 23:51
Билять такая хреновина прикольная а у меня как обычно денег нет... :( Цуко...аааа
STEED VSE=>VF750C MAGNA
Sarge
Сообщение Sarge » 20 июн 2011, 23:58
А для чего ты их заказывал то?
Сообщение endeneu » 21 июн 2011, 03:27
Sarge писал(а):А для чего ты их заказывал то?
Для FZX, но пока думаю ставить этот комплект или другой, этим готов поделиться :wink:
(хотя он и на TRX неплохо встанет ...:roll: )
Gil
Сообщение Gil » 21 июн 2011, 10:40
интересно как на стиде смотреться будет....а то яб взял...
Сообщение pride » 21 июн 2011, 10:53
Gil писал(а):интересно как на стиде смотреться будет....а то яб взял...
ИМХО Отвратительно!
Gil
Сообщение Gil » 21 июн 2011, 11:10
pride писал(а):
ИМХО Отвратительно!
Ок, отговорил =)
Сообщение pride » 21 июн 2011, 11:16
Лучше попроси endeneu, чтобы он тебе с е-бая притащил ХДшный тах и спидометр, в хроме и стрелочный ;-)
Сообщение ShaitanArba » 21 июн 2011, 13:31
Закинул элиминаторщикам, там новенький на длиннохвостом родную приборку сменить хочет.
Не знаю, зачем ему это, но может и взять.
Я правильно понимаю, что приборка:
а) есть в наличии?
б) в чёрном глянцевом корпусе?
Сообщение endeneu » 21 июн 2011, 14:10
ShaitanArba есть вот эта пара
Вид - как на фото.
В наличии.
Новенькая.
В коробочках.
Фактически не распакованная.
Сообщение brother_ilia » 21 июн 2011, 14:47
ИМХО Отвратительно!
На свой стид я бы поставил. Потому что он нео-чоп! :)
Сообщение pride » 21 июн 2011, 14:55
brother_ilia - ага, уже почти немецкая школа.
Сообщение brother_ilia » 21 июн 2011, 14:56
pride писал(а):brother_ilia - ага, уже почти немецкая школа.
... и уже почти позорит готику! :)
Юраё
Сообщение Юраё » 21 июн 2011, 17:52
Мне интересно куда девать контрольные лампочки после установки электронного спида. Вот в чем вся проблема.
А вообще где то видел, у чела был установлен спидометр от какогото легкого самолёта, который работал от потока встречного воздуха.
Такой бы найти)) Только точность думаю будет очень сомнительной))
962 680 25 06
Сообщение endeneu » 21 июн 2011, 19:45
Юраё писал(а): у чела был установлен спидометр от какогото легкого самолёта, который работал от потока встречного воздуха.
Такой бы найти))
А что делать с попутным и встречным ветром (особенно на малых скоростях) ?
Сообщение endeneu » 21 июн 2011, 20:20
Юраё писал(а):Мне интересно куда девать контрольные лампочки после установки электронного спида. Вот в чем вся проблема.
NOlim
Сообщение NOlim » 17 апр 2012, 19:59
на счет контрольных ламп. 3 шт. на траверсе зажигание, поворот, свет дальний. а где давление, где это должно быть???
Сообщение endeneu » 18 апр 2012, 01:03
NOlim писал(а):на счет контрольных ламп. 3 шт. на траверсе зажигание, поворот, свет дальний. а где давление, где это должно быть???
Это вопрос по продукции KOSO ?
NOlim
Сообщение NOlim » 18 апр 2012, 15:50
не. просто у меня каст спидометр, а под баком кучка проводов вот.
надо паходу планшетку такую с диодами и схему какой провод за че закреплен.
Сообщение endeneu » 18 апр 2012, 16:32
NOlim писал(а):не. просто у меня каст спидометр, а под баком кучка проводов вот.
Как можно заметить, данная тема
endeneu писал(а):Есть (электронный) спидометр и тахометр KOSO (комплект)
про продажу вышеозначенного оборудования
Про электрику есть тут
Электрооборудование
Про спидометры (и замену) есть тут
Спидометр ( установка , перенос , замена на цифровой )
Что куда выводить - "хозяин-барин"
Схема "разводки" есть тут
http://hondasteed.org.ru/files/wiring.jpg
NOlim писал(а): на счет контрольных ламп. 3 шт. на траверсе зажигание, поворот, свет дальний. а где давление, где это должно быть???
На спидометре или на доп девайсе
NOlim
Сообщение NOlim » 18 апр 2012, 19:28
не траверсе все работает. лампочка температуры очень нада, а она на спидометре, у меня каст там нет. кароче хочу скалхозить тока по феньшую. может знаеш какие там (еще лампочки) на родном спидометре?
Сообщение pride » 18 апр 2012, 19:31
NOlim писал(а):не траверсе все работает. лампочка температуры очень нада, а она на спидометре, у меня каст там нет. кароче хочу скалхозить тока по феньшую. может знаеш какие там (еще лампочки) на родном спидометре?
NOlim
Сообщение NOlim » 18 апр 2012, 19:41
а вот за схемку благодарствую. то что нужно я все обрыл, нифига.
а тут сразу, крутяк.
Сообщение endeneu » 18 апр 2012, 19:58
endeneu писал(а): Как можно заметить, данная тема
Электрооборудование
